Problem in I210 Ethernet controller in 6867 board
I am working with the Ethernet driver in SOM-6867 board.
I have observed that the driver is not working, if we set something other1than Auto-Negotiation in the board side (I.e. 100-Half, 10-Full etc.).
I am working with I210's internal PHY.
The sequence for setting some speed/duplexity in PHY is mentioned in section 4.3.1.4 PHY Reset of the data sheet.
I have found that all other steps are OK, but setp 7"Wait for the CFG_DONE bit (EEMNGCTL.CFG_DONE0)." not OK. This bit is never getting set.
I have tried to perform some delay(around 100ms) instead of step 7, and rest of the sequence as sequence 4.3.1.4 PHY Reset. In that case, the driver worked properly in 100/Full case.
Could anyone help in this matter.
Please note I have checked this with another different board(that means another type of target board,not the another copy of same type board). And have not faced this problem.
Comments
  • OliviaOlivia admin
    edited October 2017
    Hi sumit2310
    Could you let us know what country where you located , we can have our local AE to assist your issue?
    Thanks! :)
